KDC101 controllers stopping rest of code during movement
Hi all,
So I'm setting up a scanning probe, requiring scanning while the KDC101 motors are in movement. My problem is that during MoveRelative or MoveAbsolute the .NET functions seem to supersede everything else in the labview code. An example I made is placing a parallel loop reading out its iteration numbers, while the motors were in movement, the counter stopped and only started back up when the movement was complete. I will attach an image of this below:
Is there a good work around or error I'm making, other then two separate PCs, as this does work.
Thanks in advance,
Charlie
(2,464 Views)
Accepted by topic author Chaza
Hi Chaza,
when that driver really stops your current VI execution you might seperate the motor driver into a separate executable.
Have your main exe communicate with that separate one using UDP or TCP connection.
(2,443 Views)
