Craig,
I've tried that, and there's even an example somewhere, but I can't
remember where I found it. I've got it zipped up if you want it. I
found, however, that it is easier to use MASH (a program which you can
use for free which makes executable scripts) (Microsoft Agent Scripting
Helper) and just call the script when you need it. Using that
technique, I can actually change the script but not have to change any
LabVIEW code.
Mark
In article <8mr8oh$ip4$1@sponge.lancs.ac.uk>,
"Craig Graham" wrote:
> Has anyone yet tried using the MS Agent ActiveX interface to
incorporate
> speech input/output within Labview?
> I installed it a while back, but there seems to be no documentation
within
> the package. Casual exploratio
n of the ActiveX properties and methods
> produces a VI that looks like it should talk, gives no errors, but
remains
> silent, and I'm not sufficiently motivated myself to go trawling
through the
> M$ site and end up wasting several hours on this simply to add a
gimmicky
> touch to things.
Sent via Deja.com http://www.deja.com/
Before you buy.
