Jog Wheel on Front Panel
I am searching for  a Jog wheel /knob of sorts for controlling user input of time/frequency on the front panel.
What I would like to do is akin to the Jog wheel that we use on ham radio stations to change frequencies/channels etc. Essentially, you can use the same wheel to turn in 0.1 Hz increments, 1 Hz increments ....and even in 1MHz increments.
We need to look at a large amount of waveform data, and I want to have the functionality of moving forward, or backward in time to see different results.
Currently, we use Labview Professional Development System 8.0.1.
Appreciate your help!!
~Janak
Message Edited by mechanical13 on 04-25-2007 10:24 AM
(3,126 Views)
Hi Janak,
So I thought of a decent way to do it using an event structure.  I have posted the code and it uses graph instead of a chart.  I hope it helps.
Brian K.
(3,096 Views)
Brian,
Can you pl repost the code saved for LV 7.1 ?
- Partha ( CLD until Oct 2027 🙂 )
(3,069 Views)
Thanks a lot Brian. I think I should be able to modify it a bit and use it.
Thanks!!!
Janak
(3,049 Views)
