Jitters in waveform graph
Hi,  i am new to signal conditioning. I have a plot obtained in a waveform graph. It is obtained using sensor data, hence it has some jitters here and there. Is there a VI in labview that could help me smoothen the data plot?
Chathuri
(3,544 Views)
Accepted by topic author Chathuri
Use this moving average filer.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,542 Views)
Thanks alot for your response. I just tried it and it works perfectly and  fulfills what I want to do. 🙂
Chathuri
(3,533 Views)
Hi Chathuri,
Is your problem solved? If so please mark the post (Whichever you think is the best solution for your query). This will help others facing same problem and looking for a solution.
Balaji PK (CLA)
(3,502 Views)
