Java's MulticastSocket in LabVIEW
Hi. I am trying to implement the same type of functionality that is offered in the java MulticastSocket in LabVIEW. I want to be able to connect to a group, and disconnect, as well as recieve messages. This all works over UDP, which is part of LabVIEW, but I can't seem to find a way to implement those methods.
Any help is appreciated.
Eugene
(2,803 Views)
Yes, it looks that is not quite easy to find how Multicast Socket is implemented.
Anyway, my suggestion is to try generating an ActiveX control or DLL (using Visual J++) and calling them from LV. This way you don't have to do the hard work of implementing the protocol.
Hope this helps
(2,803 Views)
