JTFA Spectrum Frequency
Hello all,
I've generated a BFSK sinwave (37kHz and 40kHz ) via DAQ card,
and I used JTFA vi to detect the signal I've received.
Sampling rate is 1MHz, N=1000 samples.
However, the y-axis(frequency) scale corresponded to the sampling rate,
if fs=1MHz, max of y-axis is 500kHz,
if fs=100kHz, max of  y-axis is 50kHz.
Since my signal is either 37kHz or 40kHz,
500kHz is too large to distinguish them.
but if I decrease the sampling rate, the signal tend to be aliasing.
Is there any way that I can decrease the scale of y-axis but use bigger sampling rate?
(3,016 Views)
Turn off autscaling on the Y-axis of the graph. Then manually set the lower limit to 30 kHz and the upper limit to 50 kHz.
Lynn
(3,010 Views)
I've tried, but the resolution was quite low...
(3,004 Views)
If you want higher frequency resolution you have to increase the record length.
(2,996 Views)
