JSON in LabView
Hello all I Have coplicaded Json i woudl like to get vaues from but i am geting error - 375005
I have checked if JSON is vailid by https://jsonformatter.curiousconcept.com/
Please Have look
Message 1 of 11
(24,869 Views)
Hi plpablo,
The issue is that the JSON type has to match to a compatible LabVIEW type.
In the example provided the id portion looks like the following:
 {"id":1, ...
In that JSON representation the JSON Object contains a field named id with a JSON Number value.
In the example, the cluster passed to Unflatten from JSON represented id as a string:
If you change the id field of the cluster to a number it parses as expected:
Milan
Message 2 of 11
(24,829 Views)
HI Milan,
Thank You for anwser. Unfortunately i am still getting -375003 Error.
Message 3 of 11
(24,769 Views)
When I run the VI you just attached, I don't get any error.  Just a value of 1 for ID in that cluster.
Message 4 of 11
(24,744 Views)
How is possibe?
Message 5 of 11
(24,737 Views)
Message 6 of 11
(24,733 Views)
This is My first expirience witch Json so i Have no idea What can be wrong.
My LabView version is is 2017
Should I install any additional packages ?
Message 7 of 11
(24,728 Views)
I would suggest cutting down the JSON string to only the 2 first elements for now.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 11
(24,720 Views)
For two first rows works perfect i will add more and will se when in stop working.
Ok it stopped working after I add Devices section(table). But Why? What Schuld I do?
Message 9 of 11
(24,714 Views)
Accepted by topic author plpablo
Your error message says that JSON must be UTF8, but you are using UTF8-to-text to deliberately convert it to a non-UTF8 encoding.  I suspect you might be using a different LabVIEW version that is more strict about this than the version used by the other people on this thread.
Message 10 of 11
(24,695 Views)
