07-10-2022 10:02 AM
I have attached a J, T, E, and K type thermocouple to an NI cDAQ-9184. When I run my VI the readings for all thermocouples match and are correct at freezing, boiling, and room temperature. After a short period of time the readings begin to drop to about -260 C and create a sinusoidal signal. The thermocouples will read correctly again if I interact with them, AKA. apply heat. Then they will read correctly for a short period of time before decreasing into the same incorrect sinusoidal signal. I have attached pictures and my program to this post.
07-07-2022 02:09 PM
07-10-2022 11:25 AM
Hi GHAHWT,
The cDAQ9184 is just a chassis. Which module(s) do you use? How do you connect your thermocouples?
Do you get any errors from your DAQmx reading?
Please define "short period of time"…
Unfortunately you use the latest LabVIEW version many of us cannot open. Mind to attach a downconverted version of your VI? (File->Save for previous)
Your image is next to worthless as you attached a downscaled version of the image. It's just blurred and unreadable.
But still I can see "bad" code: DAQAssistent ExpressVI, lots of SplitSignal and unneeded indicators!
07-22-2022 02:51 AM
