Ivdaq.dll missing
can someone tell me what i need to install in order to find these .DLL FILES.
i have it on the other system but i am missing a whole folder on my notebook.
DAQ AND DAQMX FOLDERs
Message Edited by krispiekream on 11-12-2008 03:34 PM
Krispiekream
(4,339 Views)
i have labview 7.0 and 8.5 installed on my notebook.
it seems like all the DAQ and DAQMX folders are installed in 8.5.
I cant open the missing .dll files from 8.5 on 7.0.
what should i do to install DAQ and DAQmx on 7.0?
Krispiekream
(4,327 Views)
Krispie,
What version of daqmx do you have installed?
The last version of Daqmx that supported LV 7.0 was Daqmx 8.1, as seen here -> NI-DAQ & LabVIEW Version Compatibility
This may be somewhat complicated since I would normally not install older versions of drivers on top of newer versions...your best bet would be to remove whatever version you are currently using before installing this.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(4,295 Views)
oh...
i dont like installing versions on top of another.
the last time i tried to fix this. i got a blue screen and IT wiped out everything.
Krispiekream
(4,292 Views)
Yeah...if we use add/remove programs and remove daqmx first, it may run flawlessly, but this is always a gamble since I am not exactly sure how many folders are affected by installing daqmx.  And of course, reverting daqmx to a previous version may remove something that works well in 8.5 with the new drivers.
Is there any reason you cant open this code in 8.5 and work on it from there?
Rob K
(4,283 Views)
i have to use 7.0 because all the drivers and  the software is in 7.0.
its too much work to work with 8.5 and then save it for version 7.1 then 7.0
Krispiekream
(4,277 Views)
