02-06-2009 08:49 AM
Hi all,
I"m trying to put together a VI that will solve an equation of the form:
A = B*x^b+C*x^c
for the variable x (all others are numbers). Does Labview have a block that will do the iterative solution or do I need to make my own. I'm using Labview 8.6 Pro.
02-06-2009 08:53 AM
This is a polynomial, so you could use the "Polynomial Roots.vi".
-Jim
02-06-2009 08:59 AM
Well, a polynomial if b and c are integers. If b and/or c are real numbers then you will need a zero finder. There are two available, named "Newton Raphson Zero Finder.vi" and "Ridders Zero Finder.vi".
-Jim
02-06-2009 09:36 AM
Thanks Jim!
I'm trying to get the Newton Raphson solver going right now, but it keeps giving me a syntax error. I'm feeding it a string that looks like:
50.00=0.019231*(2*a)^0.15+675*(2*a)^0.5
I've built this string programatically. Is there something I'm missing here?
02-06-2009 10:04 AM
Newton Raphson is expecting something like "expression=0", but the =0 is implied. Try this.
0.019231*(2*a)^0.15+675*(2*a)^0.5-50
-Jim
02-06-2009 10:21 AM
