Iteration in a For Loop using a button
@billko wrote:
Well, you cannot stick them outside the loop, so it's not ANYwhere.  😉 Besides, a better experience awaits the user if you stick it inside its respective event case because then it doesn't have to wait until the next loop iteration to "unpress" again.
I think this thread is going off the rails, choo chooo : )  Just so there is a full perspective and playing the devil's advocate, this works just fine and has nice deterministic behavior (but is the behavior you want) ...
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 11 of 14
(1,009 Views)
Except that this code does not answer most of the original questions:
  • It does not create two values (one random and one set by a control)
  • It does not write them to a file.
Here's how a very simple solution would look like.
(I tend not to recommend event structures to newbies. Too many landmines 😄 )
Message 12 of 14
(997 Views)
All aboard the Crazy Train!  On a serious note, though, the button doesn't reset until after you exit the loop.
Bill
CLD
(Mid-Level minion.)
Message 13 of 14
(986 Views)
It won’t even I press then. The button only unpresses when it is read. It will have already been read so it won’t unpress.
Message 14 of 14
(974 Views)
