It�s me again with Source Code Control problems.
We use different version of LabVIEW, 5 & 6.When I create a new group in SCC it does not list VI�s that are already in SCC. The VI�s in SCC are LabVIEW 5 mine are LabVIEW 6. Is there a way around this ?
What is the advantage of using SCC and Source Safe together versus just using Source Safe alone.
Bruce
(2,722 Views)
The advantage is not using scc at all. When using Sourcesafe directly you can maintain libraries and programs and still see what is where. You can move old programs to other places and still see what you have done.
The only thing you give up is the direct compare function and some diskspace, but it is easier to maintain and a lot faster without scc.
greetings from the Netherlands
(2,722 Views)
