Issue with SoftMotion axis names across projects
I have a problem with the names of SoftMotion axes. I have two different LabVIEW projects that connect to the same cRIO real-time target. I have a few C-series modules in this target, and for each I have created and bound a SoftMotion axis. However in the two different projects (although the modules are the same) the names of the axes are different. This gives me problems when I use one of the two projects and then the other. When I try to use one of those axes in a VI as a motion resource, it can't find the axis. The name of the motion resource becomes light green instead of black - and the axis will not move, although it does move when I use the "Interactive Test Panel".
Attached are two screenshots to illustrate the problem.
I use a cRIO-9022 Real-Time target with NI 9514 C-series modules, LabVIEW 9.0.1 (2009) and Windows 7 32-bit.
Can anybody help?
Message 1 of 1
(2,290 Views)
