Issue with Multi-Channel Acquisition Using Reference Trigger in LabVIEW
I’m using a USB-6351 and LabVIEW to acquire voltage signals from two analog input channels. My goal is to acquire data from a specific time window before and after a trigger event, so I’ve applied a reference trigger (digital edge) configuration.
To perform repeated acquisitions, I’ve implemented a while loop in LabVIEW. However, the problem is that only one acquisition is completed, subsequent iterations in the loop do not perform further acquisitions.
Interestingly, if I perform the same setup but with only one analog input channel, the repeated acquisition works correctly with the reference trigger.
What is the possible issues with multi-channel acquisition using a reference trigger (digital edge)?
Are there any specific DAQmx settings or architecture changes required to support repeated multi-channel acquisitions with a reference trigger?
Thank you very much for your time and help.
(842 Views)
Help the community help you by attaching your code.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(790 Views)
