Issue while reading cfg file with custom VIA tests
Hi All,
I am facing peculiar issue in the cfg file. I have created some custom VIA tests. I have enabled few of the custom tests and disabled other. Same I have done with NI built -in test as well.
When I try to load the cfg file in someother PC, all the configurations in the NI built in tests are retained. But in the custom steps, even though i have disabled few tests, it alwayz enables all the tests.  Do anyone have an idea why this is happening???
(2,932 Views)
What is a VIA test?
(2,928 Views)
VIA = VI Analyzer
There have been some issues with storing relative paths in VI Analyzer Configuration Files in the past, but I thought I had addressed all of them. Could you use the VI Analyzer CFG Exporter to inspect the paths stored in the CFG file and see why they're not matching up on the other machine?
[edit] Now that I think about it a little more, I think I remember an issue with this scenario...can you save your CFG file in your [LabVIEW Data] folder on the first machine, then load it in the [LabVIEW Data] folder on the second machine? I think that will cause the relative paths to the [LabVIEW Data] folder to match, and it will start working properly.
(2,909 Views)
