Issue regarding importing .nce file in NI-MAX 21 version
I have created a .nce file using NI-MAX 20.0.0 version but when i am importing the same .nce file in NI-MAX 21.0.0 its showing an error shown in photo (Photo attached)
Other information:
NI-DAQmx driver installed 20.1
Labview version installed : Labview 2017
Same error was also there when NI-DAQmx driver 21.0.0 version installed.
(1,623 Views)
I have created a .nce file from NI-Max 20.0.0 version. But when i am trying to import the same file in NI-Max 21.0.0f0 an import error is pop up
"NI-DAQmx 21.0 : the import data can not be read because it was created by a newer version of this product" (Image attached).
Currently I am using NI-Cdaq 9178,compact DAQ chassis with 8 slots and NI 9202,9264,9375,9208,9485,9266 and 9213 card modules
Software version:
NI-Max = 21.0.0f0
NI-DAQmx = 21.0.1
NI-VISA = 20.0.0
(1,583 Views)
This very much sounds like a bug. I recommend to file a service request / bug report to NI for this.
Regards, Jens
Kudos are welcome...
(1,571 Views)
Have you done this on the same PC?
If yes, then how exactly?
Otherwise, it won't work according to this article.
There is one more useful article you can check.
__________________________________________
The best way to thank, is to give KUDOS
(1,539 Views)
