Issue in loading the .net assembly
Hi All,
I am using .net DLL calling in LabVIEW 2016 32 Bit.
Some times I am getting the below error in LabVIEW .net constructor:
Most of the times it works as expected but only sometimes I will get the above error.
Can anyone reply me the reason?
Thanks in advance.
Best Regards
Manasa M
(2,510 Views)
Have you read this to make sure you are targeting the right CLR version? https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OnnSAE. You should also check to see whether the .NET assembly you are using was built for x86 or MSIL in order to work with 32-bit LabVIEW.
Otherwise any details (eg. .NET Framework version, source code including assembly file etc.) would give us more to go on.
(2,480 Views)
