Issue in graph during testing.
I am running exe on window 11 PC , during running the Test graph is not coming ....Same exe I am running on window 10 graph is coming correct....what will be the issue we have face these kind of issue many times due to window compatibility.
Kindly provide the suggestion it will be very helpfull for us.
(1,028 Views)
Since you posted here, We can assume you are talking about LabVIEW. Does the problem only happen "during testing" (whatever that means) or always in W11? Does it only happen in the exe or also in the dev environment? Who wrote the program? Can you define "not coming" and "not correct"? (not showing on the front panel? not showing when printing the panel? distorted? wrong fonts? wrong colors? etc.)
What is a "test graph" (chart, graph, xy graph, etc.) What does the graph display and how is it wired (datatypes, etc.). Can you attach some simplified program that demonstrates the issue?
Have you tested on more than one Windows 11 computer? Maybe there is a video driver issue? Do you get any errors?
What is the LabVIEW version? What is the build version? What is the runtime version?
I have had a similar issue (only when printing) if a LabVIEW 2020 exe was build allowing newer runtime versions and one computer had also the 2021 runtime, which, when used by the 2020 exe, cause some traces to disappear when printing the front panel. The solution was to rebuild without allowing newer runtime versions.
(1,020 Views)
Hi
Thanks again for your quick response.
Issue was in date format.
Regards
Pooja Katariya
(906 Views)
