Issue in generating Voltage using NI 9269 with NI 7842R.
Hi All,
I got struct with this issue.
we have the following items:
1. NI 9269 Channel-to-Channel Isolated 10 V Analog Output Module
2. NI PXI  7842R
3. NI 9151 R Series Expansion Chassis.
4. SHC68-68-RDIO
5. NI PXI 1045 Chassis
6. Multimeter.
Now we have placed the NI PXI 7842R in NI PXI 1045 chassis with RT Module. Then I have connected the NI 9151 Expansion chassis to NI 7842R Connector 1 using the SHC68-68-RDIO. Now I have placed the NI 9269 in the Slot 1 of the NI 9151 Chassis.
Now we have indentified and added the NI 7842R FPGA module and NI 9269 under Chassis 1 (Connector 1) as Mod1 into my project. Then we created a VI with 4 Analog Outputs (find attachment) to generate the AO. We set some values in the VI and if we check the voltage on the NI 9269 Cards using multimeter, they are showing Zeros. Even if I ground the channels also there is no change.
Please let us know is there any issues with what we are doing?
Can we connect Analog Modules such as NI 9269 and NI 9227 to connector 1 of NI 7842R which is Completely of DIO Channels.
why we are unable to generate the voltages on the Card.
Do we need any External Power Supply.
Please help me out.
Thanks in advance.
Ramesh.
Message 1 of 1
(2,457 Views)
