Is window minimized?
How can I tell that a window is or is not currently minimized?
(3,422 Views)
I don't know without trying a few things, but in the library lvwutil.zip, there are VIs that do things like Minimize, Maximize, Restore Window as well as Get Window Rectangle. These may be of help.
Rob
(3,422 Views)
Well, there is the obvious of looking (humor....)
This is a Win API call. The lvwin utilities does not appear to contain the proper call to get this information. I would suggest determining what you need to do If you just need to show the window, then do that instead, you won't have to worry about whether or not it is already showing.
However, if what you need is to know if the window is minimized, and aren't going to act to show or hide the window, then you will need to research the user32.dll and win32.dll functions to get the exact function you need, and the parameters for that function.
If you aren't in windows, congratulations. You should have better luck interfacing with the opsys, or at least, in getting the information you need to do this.
Good luck, and please let us know how you do.
(3,422 Views)
Well one workaround is to use the VI Server property>>Front Panel Wiondow>>Is Frontmost. If the window is the active window and displayed (not minimized) then it will read TRUE. If it is minimized it will read FALSE. However watch out, It will also read FALSE if the window is open BUT another VI is active and on top of it...
Not the best but maybe you can use it in your situation since it sounds like you are looking to see if the window is active...
Michael Aivaliotis
VI Shots LLC
(3,422 Views)
