Is this a proper use of a local variable?
Linked tunnels used to crash localized version of LabVIEW from whenever they appeared up to 2017 or so
Epictetus
Antoine Chalons
Message 11 of 12
(306 Views)
@ianzur wrote:
@Basjong
By storing this log string in the private data and the indicator aren't I doubling the amount of data I am storing? (update_private_data.PNG)
No, you are storing the data in some shift register in either case. The actor object containing the log data is stored in a shift register in the actor core. In your case you are creating an additional shift register for just the log data.
In both cases you store one copy in a shift register and one copy in the front panel indicator.
Message 12 of 12
(276 Views)
