Is this a bug in the intensity map cursor?
I'm using LabVIEW 7.1 on Windows 2000. When I pan an intensity graph, it jumps around. If there is a curosr over the map, the cursor does not jump with the map and can lead to the cursor reading from the wrong pixel. I've attached a vi that demonstrates my problem. Is this a known bug?
(2,545 Views)
Excellent work on the example VI! This is not a documented bug to date, but I was able to reproduce the unexpected behavior you were talking about. I will pass your example on to our R&D department to investigate and to take corrective action if necessary. Thank you so much for your feedback and hard work.
Eric Sulzer
http://www.ni.com/ask
E. Sulzer
(2,545 Views)
