???Is there overflow problem with built-in functions Wait(ms),Wait Until Next ms Multiple and Tick Count(ms)?
???Is there overflow problem with built-in functions Wait(ms),Wait Until Next ms Multiple and Tick Count(ms)? If the answer is 'yes', then what will happen after overflow?
(2,659 Views)
Assuming you refer to "millisecond timer value", the answer is yes. The values are in 0 - ((2^32)-1) range. After ((2^32)-1) comes 0. You can find out how often happens (as I remember, something close to 50 days), but the problem is you don't know when (it depends on your application start point).
Good Luck
(2,659 Views)
