Is there any way to specify the output update rate of a DAQ Assistant freaquency task?
Thanks for the tip. I'll look into that. However at first clange I do not see any parameter in that VI that would directly affect the update rate of the output.
Message 11 of 14
(611 Views)
Hi Aleksi,
well, Min/MaxFrequency will also influence the aquisition time…
How do you want detect frequencies as low as 2Hz in just a millisecond?
Message 12 of 14
(607 Views)
We'll I'm using an incremental rotational speed sensor with 2048 pulses/rev. What would be a reasonable range then? I am expecting about 0-4000rpm which means about 0-136 000Hz.
Message 13 of 14
(598 Views)
Hi Aleksi,
usually you limit the range to e.g. 40-4000rpm.
If you really need to detect very low speeds too you need to (or should) split your measurement in two cases…
Message 14 of 14
(584 Views)
