Is there any way to prevent excess rows from being added to a table on the front panel?
Whenever I programmatically add rows through a property node I can still go into the front panel and keep adding additional rows through the table. Is there any way to prevent this "excess scrolling"? Maybe grey out the rows or something?
At least I have chicken
(2,348 Views)
Hello Labviewleroy,
You should be able to right click on the table on the front panel and select
Visible Items>>Horizontal Scrollbar or Vertical Scrollbar
You could also consider changing their visibility programmatically using a property node for the control or indicator that you are referencing. You can create the property node by right clicking on the control on the block diagram and selecting
Create>>Property Node>>Visible Items>>Horizontal Scrollbar or Vertical Scrollbar
Cheers,
-Joel
(2,319 Views)
