Is there any way to link files together in labview
Hi guys,
I am trying to link two files together so that when I read from one file and plot the data,
I open up a file that is associated to that file for the user to look through if he so wishes.
These arent the same files, the file I'm plotting from is a file that only has the magnitude
and frequency, the larger file has a lot more info.
(3,345 Views)
I think the question is: How are the two files related? Do they have similar names? Then it would just be a case of selecting one file and then automatically building the path to the second and opening that.
Remember Cunningham's Law
(3,318 Views)
In theory they would have similar names, I'm attempting to build a database so that when a user enters paramters, those parameters pass through to a funcition that filters through a folder and displays files that are similar to the inputs.
The only problem with the files having similar names is user error, someone can decide to name a file unlike it's associated file and store it in the folder, or thats how I see it anyways.
I hope that helps and isn't entirely convoluted.
(3,308 Views)
Accepted by topic author ztjackson
Need more info on how the two files are created.
You have the large file and then make a small file from it.  Have the program that makes the small file name it based on the large file name.  Then you have a pattern to open both files at once.
Or have the user manually choose both files......
(3,284 Views)
Thanks that helped!
(3,275 Views)
