cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Is there any way to jump into a certain i (iteration round) in a For-loop if a certain rule is met?
¡Resuelto!
Ir a solución
The question is in the topic.
Help is appreciated.
0 kudos
Mensaje 1 de 4
2.730 Vistas
Solución
Aceptado por el autor del tema Aleksi-
Nope.
Spoiler
You cannot influence the iteration count. It just counts up, starting from zero.
You may add an offset to "i" to "fake" a certain count value…
0 kudos
Mensaje 2 de 4
2.716 Vistas
...or use a while loop and maintain a loop count yourself using an incrementing shift register.
You can have a case structure in your loop that modifies this count under the required conditions.
Mensaje 4 de 4
2.683 Vistas
