Is there any way to hide or remove the scroll bars when programming?
I wish the vi which builded by app builder can display a interface without the scroll bars even before it runs. Thank you very much!
(2,600 Views)
As was answered here, you can only hide the scoll bars when the VI is running. If you need to enter data or set options before running, then you should redesign the application with a "Go" button or a pop-up and not rely on the user to press the run arrow. Putting the controls inside a while loop would be sufficient and should be easy to do. It's that or live with visible scroll bars.
(2,600 Views)
