Is there any direct way to control external running program window with Labview 8.5
Hi all,
I have a application which I have to control through my LabVIEW program. LabVIEW program should be able to simulate & automate all the cotrols and data of externally running window. I suppose one of the method is to use Windows API using Call Library node in LabVIEW (which looks combursome). Can any expert suggest more efficient method/idea?
Thanks in advance.
Nakul
(2,489 Views)
Hi Nakul,
if you external application has no interface (like ActiveX) to control it , then as far as i know the Windows API is the only way.
Mike
Message Edited by MikeS81 on 02-07-2008 07:13 AM
(2,482 Views)
