Is there an integration block in Labview like Simulink?
I am interested in modeling differential equations for a mechanical system in Labview. I have used Simulink in the past and there are blocks available for integration and differentiation. How can this be implemented using Labview? Thanks. Frank
(2,998 Views)
I guess that there is integration x(t) that can do the job.
However it is not causal since the integrated signal is obtained as y n =
f (x n-1, x n, x n+1 ) where x n is the singal to integrate.
Therefore, it is not reentrant like all IIR filters in Labview. I got a
Labview example making it practically reentrant for my app from
Jean-Claude Drolet last year. Thanks again Jean-Claude. It cam handy in my
vibration app.
Differentiation is a trickier business in practice since this increases HF
noise tremendously. I would suggest you make your own IIR filters to
introduce a time constant to get around this classical data processing
hurdle. Labview provides all tools to do that.
Gerard
mechanical
Regards
Gerard D'Ans (gerard.dans@laborelec.be)
Laborelec Rodestraat,125 B-1630 Linkebeek
tel 32 2 382 0568
fax 32 2 282 0241
ULB SMA (gdans@ulb.ac.be)
Blvd F D Roosevelt CP165 B-1050 Brussels
Tel 32 2 650 2515
http://www.ulb.ac.be/polytech/laborulb/index.htm
(2,998 Views)
Hi Frank,
I'm also experiencing the same thing as u do. Have you got any solution yet? Can you model differential equations using Labview? If yes, how do you do it? Thanks.
(2,998 Views)
