Is there an easy way to change the stacking order of controls on the front panel
I have two controls. I would like to place the smaller one over the larger one. Is there an easy way to change the stacking order?
Thank you,
Chuck
(2,727 Views)
Accepted by topic author chuck72352
On the top of your LabVIEW front panel, there should be a button that looks like two arrows going in a circle.
Select the large control then press 'send to back'
Cory K
(2,724 Views)
