Is there a way to tag a project or VI is broken if it includes a VI that is no longer supported?
Using LabVIEW 2010 we encountered the Open Replace Create VI that is no longer supported.
The VI compiled but failed in run time.
Is there a way to prevent LabVIEW from compiling in such cases?
(2,390 Views)
I don't see how the VI can possibly compile. You should be getting a broken arrow when you open it. Is the missing function in a VI that you call dynamically?
(2,379 Views)
What do you mean "failing"? Are you sure you aren't just getting an error which is being returned from that function?
(2,369 Views)
Hey ATE,
I'm not sure what you mean by "the Open Replace Create VI is no longer supported."  If you are refering to the Open/Create/Replace File Function, it is supported in LabVIEW 2010 and the help file can be found at Open/Create/Replace File Function.  Runtime errors should be seen by the error out tunnel of the VI.  To see what the error is, you can place a probe on the wire out.
Jake
Jake G.
(2,345 Views)
