Is there a way to set mouse cursor in Xcontrol?
In my Xcontrol, I want to change "mouse cursor". But I found I can only change the cursor in the VI ,which contains my Xcontrol.
As a example, I edited the labview example "Dual Mode Thermometer". In facade/Data Change event, I set cusor to 2. but it didn't work?
(3,575 Views)
Accepted by topic author superlvjf
Here's an example to change the cursor when the user hovers the thermometer
This Mouse Enter is for the VI class of the Facade VI:
Simple Dual Mode Thermometer XControl.xctl_Simple Dual Mode Thermometer Facade_BD.png
I have a similar setup for the Mouse Leave event with the value 1.
Ton
My LabVIEW Ideas
(3,559 Views)
Thank you,Ton .
It works.
(3,525 Views)
I have an XControl within an XControl on a dynamic VI.  The innermost XControl has an intensity graph and depending on what happens in the mouse click event, I may want to switch my cursor to a red X.  When I do this, it doesn't work right, but always switches to the hand cursor.  I've tried the above solution but it made no difference, presumably because this XControl is on the facade of a different one.  The automatic cursor changes work fine, like when I select different tools on the graph palette.
Tim Elsey
Certified LabVIEW Architect
(3,246 Views)
