Is there a way to "query" a 2D array with pseudo-SQL code?
Hi all,
I'm using LabVIEW 2016. I have a TDMS file to which I'm recording data almost in a database-table style, in the sense that I have an index column that I want to use to pull out rows that have a matching value of the index column.
Now I can get the 2D array using TDMS Read. But then to pull out the rows that have a requested index column value, I have to go through multiple hoops of getting the value, then looping through each row and collecting the rows with matching index column values.
With SQL, I can accomplish this with a very simple query:
select * from [2D array]
where [Index Column]=1
Except, instead of a formal database table, I have a 2D array (essentially a table).
Is there such a "pseudo SQL" way to do this in LabVIEW?
Thanks!
(4,184 Views)
Multiple hoops?  Is there something wrong with doing it like this?
(4,164 Views)
I did that exact for loop first. But it's not very convenient or scalable. If I want to do a more complex data extract, I'd have to do more of these clumsy operations. At least if there was a "Search 1D Array" that would find all instances of a value, it would make the code a bit more compact.
(4,145 Views)
OpenG toolkit has one such function that returns the indices of the array that match your value.  You can install it from VIPM.
aputman
(4,137 Views)
@abvenk wrote:
... I'd have to do more of these clumsy operations. At least if there was a "Search 1D Array" that would find all instances of a value, it would make the code a bit more compact.
There is nothing clumsy about this code, it is quite elegant. To make the code more compact, turn it into a subVI. 🙂
What "more complex" searches do you need to do?
(4,117 Views)
In case the OP was unaware, one can use SQLite (full SQL database-in-a-file) in LabVIEW.
(4,104 Views)
