Is there a way to make a numeric control blank after entering in a value
I would like to make a numeric control blank after entering in a value.  Is that possible?
Message 1 of 21
(1,275 Views)
Numeric controls by their nature always show a number.  They can't show "blank".
One alternate options is that you could use a String control instead, and just generate errors if someone puts something into it that can't be parsed as a number.
Without knowing your real objective here though it's hard to suggest other possible alternatives.  What are you really trying to do overall?
Message 2 of 21
(1,265 Views)
Or you can use the String "Key Down?" event to filter out unwanted Char to mimic a numeric control.
George Zou
Message 3 of 21
(1,226 Views)
You could make the font color the same as the background color except when hovering with the mouse over it.
Message 4 of 21
(1,211 Views)
Never say never... that is some out-of-the-box thinking. 😁
Message 5 of 21
(1,207 Views)
Do you catch the value change event also?   OP wants blank "after entering in a value".
We can't test your picture 😉
George Zou
Message 6 of 21
(1,201 Views)
Well, that could easily be implemented with a bit more code once we have all requirements. We don't!
Currently the indicator is blank unless the mouse hovers over it. Should the user be able to enter a new value later or never again? In my case, we see what is being entered while the mouse is over it. Also how should the control look like before a value is entered?
It would be simple to expand the code ... I still don't see the purpose of all this! How does the operator benefit from a blank control?
Message 7 of 21
(1,189 Views)
1. mouse enter is not a proper event.  Does touch screen trigger mouse enter event?  What if user use the Tab key instead of mouse?  I would use KeyFocus event if I could 🙂
2. mouse leave is not proper event either.  Think about this scenario: user start to enter number, but before he finish, he moves the cursor out of the way, and then blank.
George Zou
Message 8 of 21
(1,180 Views)
Not completely true. There is a hidden/unofficial property "HideText" that does exactly that.
Message 9 of 21
(1,174 Views)
Wait, what?
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 21
(1,138 Views)
