Is there a way to enter a "kind of" polymorphic data into a Vi in the Full Dev. System?
I'm using a LV 7 Full Development System so I cannot create polymorphic Vis.
I'd like to enter data to a Vi but it can be a string or a number. Inside the Vi, the data goes into the Default Data terminal of ReadRegistryValueSimple.vi. Since the Full system doesn't have the option of creating polymorphic Vis, I'd like to find a way to convert my data into a variant or a string and convert it back into the original type inside the Vi.
Does it have any sense? If so, any hints?
Thanks much,
Marce
(2,350 Views)
Look in the function pallete for variant, also search the examples for variant. You can also download a great set of tool from openG.org. download the commander and install it. It will become a tool you cannot code without.
Joe.
"NOTHING IS EVER EASY"
(2,337 Views)
