Hi
I would like to fit a least squares curve to a set of data points. I see I can do this using general LSQ fit.vi or Levenberg-Marquadt, but these VIs seem to only handle implicit functions of the form y=f(x,A).
What if I have a data set from a known implicit function, for example a circle:
(x-x0)^2 + (y-y0)^2 - r^2 = 0
How can I calculate the x0, y0 and r that minimizes the square error? Can this be done using the L-M VI or a VI from a different toolkit?
Thank you.
__________________________________
Laine
