Is there a way to build a font into a executable?
Hi All,
I'm using a font type which is usually not preinstalled on Windows 7.
Therefore, when I run the executable on an other PC, all Indicators have the default LV font.
Since I don't want to install my font on the customers PC ( because of Licensing, etc) my question is how can I build my font into the executable?
Stay Hungry, Stay Foolish
(3,287 Views)
Unfortunately, you can't.
With Windows (and most other OSs?) fonts are considered a system resource so if you want to use a font in an application you have to install it on the target computer along with your executable.
Why do you need to use a specific font?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,251 Views)
The option is to export the texts as images and use those.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,241 Views)
if the desired font is installed on the target, you edit the xxx.ini for example by adding:
FPFont="Courier" 30
BDFont="Courier" 30
appFont="Courier" 30
dialogFont="Courier" 30
systemFont="Courier" 30
(font and size)
The font "Courier" must be installed on the target
(3,188 Views)
Better opt for times new roman. becasue you will not need something changed by customer.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,180 Views)
Thank you for all your comments.
I think I have to find a way to install it because all your software should look the same, with same font etc.
Next time I will fight for times new roman.
(3,142 Views)
