02-16-2012 12:25 PM
02-16-2012 12:31 PM
I think they would be better served if you put them in a user library so that way in the future they are easier to move when you do have to upgrade LabVIEW. It seems that they would be easier to manage too.
I have all kinds of special VI that modify existing LabVIEW stuff and I keep them in the user library. This way I just pick up my user.llb floder and move it to the new version and I have everything.
02-16-2012 12:31 PM
I just tried to explore the Excel report gen toolkit. In that one when you open a Method (Invoke node) of an excel worksheet you have one option called delete after giving the name of the worksheet that you wanted to delete use the method and check it. Even I have never tried these sort of things.
02-16-2012 12:38 PM
Yes It is working I am able to delete the worksheet. ![]()
02-16-2012 01:53 PM
It not clear exactly what you mean. but as an alternative I found the Excel Get Active X References.vi in the toolkit, I can use this vi with the delete method. Initially the issue I had was that you can't unbundle the Excel report to get acces to the activeX references when you're outside the NI_Excel.lvclass (as in the following picture).
Ben64
