Is there a way for LabVIEW to know if the computer has an ethernet connection active?
I need to know in my VI if the computer has a network connection, to avoid trying to connect through TCP/IP when the connection is not available. I would prefer to know if there is a connection available rather than rely on errors coming from the TCP/IP functions not being able to connect.
Windows instantly knows when a network cable is unplugged. Is there a function in LabVIEW that can similarly instantly detect a connection?
Or, does anybody know if there is a Windows-provided dll that contains the function that the taskbar indicator uses to know if there is a connection present. If there is, then I could call the dll from LabVIEW and know the connection status.
Thanks.
Alejandro
(2,901 Views)
You could use System Exec to run the ipconfig command and parse the return string. You'll get a Media State:Cable Disconnected when the cable is unplugged.
(2,893 Views)
Hi there,
there`s an API
unsigned long WNetAddConnectionA(CStr lpRemoteName, CStr lpPassword, CStr lpLocalName);
in mpr.dll.
lpRemoteName the address of a network resource (e.g. "\\YOURSERVER\YOURDRIVE")
lpPassword may be NULL
lpLocalName should be NULL, otherwise the API maps lpRemoteName to the drive you specify in lpLocalName (e.g. lpLocalName = "e:")
if all is ok, the API returns 0, otherwise some errorcodes.
more info can be found here
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/wnet/wnet/wnetaddconnection.asp
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,866 Views)
