Is there a function in LV comparable to the Matlab function imagesc ?
Am trying to look for a labview function that mimics imagesc function in matlab. also cannot read in data when using matlab script node. help!
(2,803 Views)
Let's focus on your Matlab Script Node problem for now. There are a couple of possible sources.
First, take a look at the KnowledgeBases titled LabVIEW 6.x and Earlier Does Not Interface Properly with MATLAB 6.1 or MATLAB 6.5 and LabVIEW 7.0 Hangs When I Place a MATLAB Script Node or Load a VI That Already Contains a MATLAB Scri.... Each of these contains a drop-in replacement .dll and instructions on how to use it.
A similar issue has recently surfaced with Matlab 7.0 and LabVIEW 7.x. R & D is aware of
the problem and they are currently working on a solution. Unfortunately, if this is your situation, the only immediate fix it to downgrade your version of Matlab.
I hope that this helps.
P.J.
(2,803 Views)
I couldn't find a function in Labview comparable to the matlab function imagesc. Please tell me if there is any...
(2,419 Views)
