Is there a better way to do this pop up?
I suspect even your oldest Users have used other computer programs in the last decade or so.
Message 21 of 23
(1,147 Views)
Accepted by topic author bobausttex
Well as sad as it sounds I found that all I had to do for the bulk of my display screen pop ups was to put the window in Float in the custom window settings.  I don't think that was an option at development time in the 90s.  I thought I had tried that first thing but it must have fooled me.  On any window that I do not need to stop data collection for and only has data going to it this seems to work and allow the sub vi to have a loop and be closed by a button without interfering with the main vi.
Message 22 of 23
(1,092 Views)
Above, you said "and have the pop up not interfere with the operation of the main vi".
I think most of took that as a programmatic issue, not a user interface issue, at least I did.
Go figure.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 23 of 23
(1,076 Views)
