Is the latest LabVIEW 2015 SP1 compatible with Veristand 2015?
I think it is, but can someone confirm it?
Thanks.
Ian
(3,294 Views)
I saw that too. It just mentioned LabVIEW 2015, but not LabVIEW 2015 SP1.
In the case of Veristand 2013, it is compatible with both LabVIEW 2013 and LabVIEW 2013 SP1. So if I apply the same logic, Veristand 2015 should be compatible with LabVIEW 2015 SP1.
Anyway, I am installing LabVIEW 2015 SP1 and Veristand 2015 on my computer now, I guess I am going to find out soon.
Thanks.
Ian
(3,257 Views)
2015 SP1 just came out.  That document hasn't been updated since August 2015 right after  2015 came out.
I'm sure it is.   There are never any major changes to an SP1 version that would cause it to stop working.  (Interestingly, 2012SP1 and 2014 SP1 aren't listed, but that is probably an oversight.)
(3,247 Views)
I wouldn't be too conserned, as stated SP1 releases don't break compatibility as far as I know.  But at the same time I'm not sure I would take on the added risk of it not working, unless there was something in 2015 SP1 that I wanted.  Bug fixes or new features, or whatever.
(3,186 Views)
