Is the State Diagram Editor included in the NI Developers Suite?
Ben,
Thanks for submitting a request.  -SS
Message 11 of 16
(976 Views)
On Apr 8, 11:40 am, ShotSimon <x...@no.email> wrote:
> Wow such an enthusiastic response.&nbsp; I think from now I'll just put State Diagram in all my posts 🙂
> Unfortunately now I'm thoroughly confused and still don't know if I have any State Diagram &lt;fill in blank&gt;? Or where that wonderful tool may or may not be located :)&nbsp;
> I do not see anything related to State Diagrams under add-ons.
> FYI...I just got my NI developers Suite disks for Feb 2008 and an email notice to download online as well.&nbsp; I'm holding off to see if it's in my existing software.
> I'm currently running the latest version before that but only have the Internet Toolkit installed.
> I do not have an add-ons disk just one labeled Toolkits, unless addons is hidden in another disk now.&nbsp; I'm reinstalling this.&nbsp;Regards,
> &nbsp;
> SS
This Web Page http://ohm.ni.com/advisors/devsuite?rec=Industrial_Monitoring&rec=Realtime
says the Statechart Option is not included in the Develper Suite
Bundle. It is An $899 add-on.
Howard
Message 12 of 16
(960 Views)
Howard
Yes, but the one that is mentionned there is the Statechart Module and not the State Diagram Editor. Open this page, click on Statechart Option to display the details and then on NI LabVIEW Statechart Option to convince yourself.
Message 13 of 16
(945 Views)
The SDE is not available distributed as part of the LabVIEW developer suite. I have asked this before
Here's the repsonse from my NI rep:
Eerder heeft u met mijn collega Casper Klop gesproken over de state diagram toolkit. U heeft terecht geconstateerd dat deze niet meer met de nieuwe Developer suite releases wordt meegeleverd.
National Instruments heeft besloten geen ontwikkelingen meer te doen in de state diagram toolkit. Naar het blijkt wordt deze toolkit zeer minimaal gebruikt (dit is gebasseerd op diverse survey's). Met het stopzetten van de ontwikkeling in deze toolkit is ook besloten de betreffende toolkit niet meer actief aan te bieden, de toolkit zal na enige tijd van onze website verdwijnen en is vanwege dit ook uit de Developer suite gehaald. Dit houdt echter niet in dat u de toolkit niet kunt gebruiken. De state diagram toolkit wordt vanaf Labview 7.0 door alle Labview releases ondersteund, over de toekomstige releases kan ik echter geen uitspraken doen. Voor installatie van de toolkit kunt u daarom de mei release van de Developer suite gebruiken.
It states that they stopped developing the SDE, because of this they stopped actively distributing it and it will be dropped of the website. To install the the SDE you will need the may (2007) release of the Developer suite.
Ton
My LabVIEW Ideas
Message 14 of 16
(938 Views)
It states that they stopped developing the SDE, because of this they stopped actively distributing it and it will be dropped of the website. To install the SDE you will need the may (2007) release of the Developer suite.
Ton
Although this explains the divergence of our answers this is VERY bad news !
Thank you Ton for sharing your knowledge about this topic.
Message 15 of 16
(932 Views)
On Apr 9, 1:10 am, JB <x...@no.email> wrote:
> hrh1818 a écrit:
> This Web Page http://ohm.ni.com/advisors/devsuite?rec=Industrial_Monitoring&rec...
> HowardYes, but the one that is mentionned there is the Statechart Module and not the State Diagram Editor. Open this page, click on Statechart Option to display the details and then on NI LabVIEW Statechart Option to convince yourself.
Thank you for your update. I didn't realize National Instruments was
selling two separate products at one time with similar names.
Howard
Message 16 of 16
(908 Views)
