Is the 2013 LabVIEW Simulation Loop supported on the cRIO-9068?
I tried to use the LabVIEW Simulation loop with my cRIO-9068 today. I was quite disappointed. Apparently the 9068 is not supported by the 2013 Simulation Loop. Is that true? I had two problems: (1) the download failed indicating that the LVSim shared library was not found, (2) no support for the 1MHz clock. I can select and use the 1MHz clock just fine with the Timed Loop but not the Simulation Loop. However, a VI with a Simulation Loop can't even be downloaded.
Is this just an installation/configuration problem on my side? Has anyone else had success running a Simulation Loop on the 9068?
(2,594 Views)
You will need to install support for Control Design and Simulation on the target through MAX before you can run a Simulation loop on it:
I believe this needs to be intalled on any RT target in order to run a Simulation loop.
Chris M
(2,585 Views)
Turns out there is a bug in the control design and simulation loop that makes that option not appear for the 9068 (or other NI Linux Real-Time targets).  I created a KB with two VI's you can download and replace their existing copies on disk with to fix the issue.  The KB is located here:http://digital.ni.com/public.nsf/allkb/BF55BC02A4F7C0E286257CAC00618EFB?OpenDocument
Let me know if you have any issues with this - I agree with the steps Chris mentions above - you will first need to install CD+SIM support to the target.
Kevin Fort
Principal Software Engineer
NI
(2,520 Views)
Thanks Chris and Kevin,
I had tried the steps Chris suggested before making the post but I didn't see the CD/Sim option. I'll admit I was in a hurry so I must have missed it. After Chris' post we tried it again and found the DLL for downloading.
I'll try out Kevin's suggestion for fixing the 1MHz timing bug. Thanks all!
(2,512 Views)
