Is neccesary to initialize an array of indicators to be able to show my results?
I am working using Labview 7, and I have a problem when I have to show my results in an boolean indicators array.
The problem is that I have to initialize the array to see the results.
Is it normal or am I doing something wrong?Has it any solution?
Thanks in advanced.
Graci
Message 1 of 11
(3,653 Views)
No it's not normal.
Look at this exemple. Make it run continiously.
If you reverse your array, you must resize to correct size.
Message 2 of 11
(3,652 Views)
Could you explain what you mean by "Initialize the array"?
Maybe you could attach an example.
Message 3 of 11
(3,651 Views)
Hi BBLab!
I have seen your example.
And you can see my problem is this example, in the second array you only have initialized 8 positions in the array (you use 8 bits, and you have written a value in the first eight positions). If after doing that, you try writting a value in the position 12 of the array2, it is not posible , you have to initialize at least 13 positions to be able to write a value in the position 12! This is my problem , I have to write a default value in my indicator array, but I don´t know how many positions I have, so, how many values do I have to write?
And if the only solution is writting a default value in the array I have other problem. I have to write these default values the first time that I execute this vi,a posible
solution is using the function "First Call" but I need a while loop, and I can´t use a while loop because this loop would stop my data flow and it is not possible in my application and using global variables is not an option for me!!
What can I do?
thanks for your help!
Graci
Message 4 of 11
(3,651 Views)
Hi!
"Initilize an array" is that you have to write a default value. And if you don´t have written this default value you can´t write a value in this array indicator. I send an example, Exemple_Array_bool_mod, where you can see this!
thanks!!
Message 5 of 11
(3,651 Views)
As your example shows with the indicators Array and Array2, you don't have to initialize an array to write to it. If, however, you use the Replace Array Subset, there has to be something in the array to replace before you actually replace it.
Message 6 of 11
(3,651 Views)
Thank you!!
So, the problem is the function that I am using!!
If I want to write a value in an array, and before doing this I don't want to write a default value. What function can I use? I know that Insert Into array doesn't work properly in my application!
Thanks in advance!
Graci
Message 7 of 11
(3,651 Views)
You could possibly use the Reshap Array function. In the example, if you first Reshape the Array and use 13 as the dimension size, then your Replace Array Suobset function would work correctly.
Message 8 of 11
(3,651 Views)
I do not understand why you convert the number to U8, leaving you only 8 elements for the resulting array if you later want to replace element #12.
Whay don't you just remove the "to U8" node, and you'll have 32 booleans in the resulting array to fiddle with. It does not make much sense to create an arbitrary length boolean array from an unsigned integer input with defined width. (If you only need 16 booleans in the array, replace it with "To U16").
Message 9 of 11
(3,650 Views)
Thank you!!
It works properly!!
Thank you, thank you, thank you!
Graci
Message 10 of 11
(3,650 Views)
