Is it possible to turn a devices power on or off at specified temperatures?
The device turns on and heats up to a specified temperature. It needs to be turned off until it cools down to a lower specified temperture, where it will turn back on and heat up again. The device needs to fluctuate between these two temperatures for a time limit of 40 minutes.
(2,836 Views)
Accepted by topic author Hasselhoff
Yes its very possible.  you need some means to read the device's temperature when its power is on and off. and some means to control the device's power.  The rest is easy.
"Should be" isn't "Is" -Jay
(2,825 Views)
thank you! much appreciated!
(2,809 Views)
