Is it possible to specify a starting FILE for the browse button dialog?
I realize I can specify a starting directory/folder PATH for the dialog window that opens when the Browse Button for a file path control is clicked.
Is there also a way to programatically preset the "File Name" field in the window that pops up?    (for LV v7.1.1)
Message 1 of 8
(4,063 Views)
I cant find a way to do it with the Path control.  I know it is possible using the File Dialog vi in File I/o> Advanced.
Not sure if you can have the user select a folder and then add in the file name afterwards, using property nodes
Good luck.
Kenny
Kenny
Message 2 of 8
(4,056 Views)
I could not find a way to do this even with the advanced file dialog. I did come up with a way to do this using .NET. Feel free to use it or not. I coded this up as a proof of concept so it does need more work. You could also code in to set your own favorites.
Joe.
"NOTHING IS EVER EASY"
Message 3 of 8
(4,042 Views)
You could use a normal path control (without browse button), a browse button boolean control, openg has one. And use a value change event (in that way you can force user to use the dialog). In the event case you can use a browse function where you can set a filename.
Ton
Edit: I am not totally sure for 7.1...
Message Edited by TonP on 12-15-2006 05:30 PM
My LabVIEW Ideas
Message 4 of 8
(4,038 Views)
Hmmm... the file dialog has a "default name" input that seems to work just fine for this purpose.
Message 5 of 8
(4,025 Views)
(DOOH):smileyvery-happy: Sometimes I over complicate my life. I guess I just looked over it.
Joe.
Message 6 of 8
(4,021 Views)
It worked for me ;    The "Default Name" will be your starting FILE...
Message 7 of 8
(3,392 Views)
It just reminds me the Rube Goldberg code
Message 8 of 8
(3,384 Views)
