Is it possible to simulate EtherCAT devices in a project?
Given a project topology like this:
Windows PC Host  <-> cRIO-9024 <-> NI-9114 backplane <-> NI-9144 EtherCAT #1 <-> NI-9144 EtherCAT #2  run in hybrid scan mode
During development is it possible to tell the project to run without EtherCAT #2 being physically connected, using virtual/simulated IO in place of it?
Just trying it, when I try to switch from Configuration to Active mode, I get an error saying that "the slave device cannot be found".
I often find myself thinking that the project explorer needs a good way to "comment out" various pieces of the project without having to resort to "Remove From Project".
(3,487 Views)
Hi WNM,
Unfortunately, it is not possible to run the project without the ethercat slave device connected.  That does sound like a very useful suggestion though!  I recommend that you post to the NI Idea Exchange with your ideas for this.  http://forums.ni.com/t5/NI-Idea-Exchange/ct-p/ideas
Dayna P.
(3,463 Views)
I wish it were not as you say, but I thank you for taking the time to answer Dayna.
Per your suggestion, I submitted the idea to the exchange here.
(3,446 Views)
Is it still not possible?
(1,217 Views)
