Is it possible to save a data portion starting from when a "save" button is pressed?
The below attached vi acquires data from a sensor. The sensor signal output can be reset to zero and the data saved into a file. However, the saved data comprises the data portion starting from when the vi starts running until the "stop" button is pressed. Is it possible to save the data portion starting from when the "save" button until the "stop" button are pressed?
Ninjatovitch
Message 1 of 8
(3,303 Views)
for this case you can either use a case structure or an event structure
I looked at your code you might want to put the save case structure iside the While loop
Message Edited by Harold Timmis on 10-29-2009 09:15 AM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 8
(3,301 Views)
Hi Harold,
Thanks a lot for your quick answer. I tried to put the "save" case structure inside the while loop but I get the same data portion saved.
best,
Ninjatovitch
Message 3 of 8
(3,284 Views)
it sees to be working on mine or at least i think it is working as you want it to here is an example
you will have to change the constant on it
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 4 of 8
(3,277 Views)
Thanks for your answer. Unfortunately, I can not open your vi, I am working with LabVIEW 8.2.
best,
Ninjatovitch
Message 5 of 8
(3,274 Views)
Accepted by topic author Ninjatovitch
this should be in 8.2
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 6 of 8
(3,270 Views)
Thanks a lot for your vi in LabVIEW 8.2 version. I tried it, but does it save the data only after you press the OK button? It is difficult to see, given that
the output numbers are randomized.
In my vi it does not work. Below, you can find data of the sensor output signal that corresponds to: first the sensor offset, then the output signal is set
to zero, then the "save" button" is pressed and finally, the sensor is bended a few times. Unfortunately, I get the whole data portion.
best,
Ninjatovitch
Message 7 of 8
(3,264 Views)
well I have looked at the data on mine what I did was made the button latch untill released so it will collect data until the ok button is false.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 8 of 8
(3,258 Views)
